Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Sounds simple doesn't it? Just a little work and I'll fix this rascal myself!
Hah! Buyer/fixer beware as this story will tell you, post your experiences to.
I bought a Kershaw Random Task from a nice guy at a local show last year.
It opened real tough, and the angled thumbstud had nicely sharpened
edges that took skin off each time I tried to thumb the knife open! I was told
by a fellow forumite that I needed to build up my Onionskin, LOL
Well, methinks, if I made the ramp to where the thumbstud was positioned a
little deeper I could get a better position on it and it may open easier. So I took
some sand paper and a round rod, wrapped the sand paper around the rod and
started to sand away a ramp. Wasn't too long till a hole appeared in the G10 material.
I thought to myself `Hmmmm must have been a bubble inside when they made the
stuff, no problem I'll just fill it with Devcon 2part epoxy and then sand and polish
that down, no big deal ..famous last words.
I made the ramp to my liking, so I mixed up some epoxy and started forcing the
epoxy into the hole, as I went to close the knife the epoxy was sucked further into the
hole! Well!, said I, it must be a bigger hole than I thought! So I just dumped some more
epoxy into it and then tapped the sides to ensure that I filled every nook and cranny
that was open. Satisfied that I couldn't get any more into the hole I started to close the knife
again, BUT this time I noticed a metal bar sliding up and back past the hole! Great Scott!
I just turned my folder into a fixed bladed knife! I let out a blood curdling scream, which
sort of got my wife's attention. I just sat there and realized that the Torsion bar travels almost
the whole length under that scale! I thought it must have been a coil spring like some autos
but NO, it isn't, (hence the name torsion bar). To make matters worse I didn't have a torx
wrench small enough to remove the scale, so I reached for some WD-40 and sprayed the
heck out of that, hoping that it would prevent it from seizing up. Which it did to some extent.
I emailed this sad story to Kershaw, but didn't get a reply quick enough, I was panicked you see,
so I called and talked to a nice lady there, who was very very help full. She said there were some
problems with the earlier versions and would replace the knife for me! I told her that I really
screwed up the scale, she said no problem and that was that! I couldn't have been more relieved!
So, don't go getting ideas on modifying your knife, unless you are qualified!
G2
"The Road to Hell is Paved with Good Intentions!"
Take the time to read your Bible Now, don't be left behind...
G2 LeatherWorks
G2
G2 LeatherWorks
