Don’t need loctite that sets hard and then breaks loose as soon as you turn it. Want to be able to do minimal adjustments without removing screw and re-applying each time. I’m learning that Benchmades need adjusting all the time, even after being broken in.They make different grades of loctite. Get the purple loctite, it's the lowest strength grade, made specifically to not hinder easy disassembly with hand tools but still prevents inadvertent loosening
That's strange. Where did you learn that? My Benchmade knives don't require adjusting "all the time". I carry a Taggedout everyday and it has never needed adjustment. The only reason I can think of why a Benchmade would need frequent adjustment is that the person assembling it did not use Loctite.Don’t need loctite that sets hard and then breaks loose as soon as you turn it. Want to be able to do minimal adjustments without removing screw and re-applying each time. I’m learning that Benchmades need adjusting all the time, even after being broken in.
It comes in a red bottle. https://next.henkel-adhesives.com/u...es/central-pdp.html/loctite-222/BP000340.htmlAin't 222 the purple?
What’s a good compound to put on threads of a pivot screw thats sticky enough to stop it backing out but won’t set hard like loctite.
Reading directions is good, yes.And if you don't read the instructions, you don't know what you have or how to use it.
Thanks! Finally a simple answer to a question that, to anyone with an IQ that reaches double digits, should have been pretty simple.Vibra-Tite VC3 Threadmate
I've used it myself and it works great on pivot screws.
It is intended specifically to resist shock and vibration, so it doesn't dry hard. It becomes gummy or rubbery instead. It starts to set pretty quickly too. It's bright pink colored as well, so you can immediately tell it apart from Loctite. It also doesn't react with plastics, unlike loctite which I found out can dissolve the plastic scales on my swiss army knives!
You can buy it in a little tube just like loctite, or you can get it in a bottle.
I didn’t ask "the proper type of loctite". Your post doesn’t pertain to anything I asked. Better find a new drug dealerThe proper type of Loctite? There are a BUNCH.
You need to use the correct product for the results you're trying to achieve.
You sure have a strange way of asking for help.I didn’t ask "the proper type of loctite". Your post doesn’t pertain to anything I asked. Better find a new drug dealer
