here's what happened to me yesterday. I'm not at all skilled in sharpening, and what might have worked last week doesn't necessarily work again today.
A couple of months ago I bought a beat-up Case USMC "kabar style" knife but couldn't get any kind of serious sharp onto it. So yesterday evening I went over to TheMart and bought one of those plastic $5 yellow thingies with the fixed-angle carbide cutters. You've seen the kind, you rest the knife edge-up on the table and draw this sharpener down the blade.
What I did was clamp the thingie in the vise and pulled the Case across the cutters... wow, all kinds of metal came off the blade. It wasn't quite like the amount of chips a lathe will toss, but I was nonetheless quite surprised at the quantity.
So I pulled the Case through about 15 times, each stroke feeling more solid (more "bite") each time, I reckon the edge was really getting re-profiled. The edge seemed kinda rough when I was done but it would cut arm hair.
Then I got out my leather-glued-onto-a-mousepad strop, rubbed in lots of green oxide stuff into the leather, and wailed away for awhile, back and forth.
The "sharp" doesn't necessarily qualify as what I'm guessing the experts would call "scary sharp," but there was no problem harvesting plenty of arm hair.
Thinking I was onto a good thing here, I then grabbed an old near-WWII era Camillus "kabar style" knife from the box of toys and gave it the similar treatment. It too had resisted getting sharp, but once again the technique worked and the arm hair harvesting was very successful.
So I decided this was really working fine so I grabbed my almost new Kabar 1211 and gave it the treatment.... success !!
Then a 6" blade WWII-era Kabar MK I...... success !!
I have no idea what the angles are, but I do know that all those knives now have some very serious "sharp" attached to them, thanks to a $5 sharpener and some green-oxide stropping. Quick and "easy."
Cheers,
Carl
p.s. also of interest is that I have a SOG X-42 Recondo with something of a re-profiled edge to get away from the chisel-style. I've had a perfectly miserable time trying to get that edge arm-hair-cutting sharp. The Recondo has a very very hard BG42 steel and I discovered that the carbide cutters didn't seem to cut the BG42. I put some real pressure on the blade as I drug it through the cutters and it didn't seem to "grab hold" like the 1095 steel of the Kabar's. The BG42 did seem to get a bit sharper, but wow, that is some kinda hard hard steel.
