How to sharpen a Mora Clipper?
Can the Clipper be sharpened in a Sharpmaker? if so which is the correct angle? Thanks
i dont own a Mora, but i would use the 30 for a thin edge, or just make a microbevel with the 40 setup
you can mark the edge with a marker, and check from where you are removing metal
You can, but it will cease to be a scandi grind. It'll still be a screaming cutter, though.
yes, you are right
to mantain the scandi grind, i guess you could use the sharpmaker, just lay flat each grind on the stones :D
maybe its easier to do that freehand, with the stones laying flat on the plastic case
yes, you are right
I had hoped it had a 30 or 40 degree, in that case I just had to use the Sharpmaker the usual way....well I think i will have to go the hard way....Thanks
Just use a benchstone, scandi grinds are the easiest to sharpen, lay the blade flat on the stone, raise the angle till the edge clicks and locks in, then use that angle.
