Hey everyone, been a long time forum reader but this is my first post! (Well technically, my second, the first was in the wrong forum!)
I purchased a new Wetterlings Bushman Axe and fell a small hardwood tree this evening, after which I noticed the toe end of the bit had curled over! Disappointed but not surprised, as I had read about issues with this axe. The factory edge it came with was rather sharp, which I'm suspecting is the cause of the failure? The Bushman is fairly wedge shaped which seems optimized for splitting, so why put a thin edge on the blade? I know it's supposed to be for bushcraft, but what good is an axe if you can't take down a small tree?
Anyway, to my actual question. How do I fix this? Should I use a wet axe stone in a circular motion to grind off the curled toe end? What about the rest of the edge? Should I make it more dull? How do I do this?
I've watched several videos on sharpening axes but could not find any about fixing a curled edge. Is the term 'folded edge' correct? There is also no specific instructions on how to make an edge more dull.
I'm new to edge sharpening in general, so any help or direction to resources would be appreciated.
Thanks
Thanks
