- Mar 11, 2011
Made a handle for my ALICE pack. Very easy to do, and makes handling the pack much easier.
I took a piece of 1/2" pvc, and cut it off around 4 1/4". I lightly sanded the ends, to knock the sharp edges off.
I then painted it with this Krylon camouflage Fusion paint:
I took a piece of coat hanger, and fashioned it like this, so the hanger wouldn't touch the inside walls of the PVC, on the ends:
I also made a hook on the other end, so I could hang it up to dry:
As you can see, the hanger doesn't touch the insides, on the ends. I wanted to make sure I was able to get some paint on the inside. It worked very well:
Make sure not to make the loop on the end of the hanger too
tight, otherwise it will scrape the paint off while pulling it out, after it dries.
I then took a length of OD 550 paracord, about 23" long. Loop it through the upper portion of the ALICE pack frame:
Then put both ends through the PVC:
Place one end of the cord under the frame:
Tie a knot in the cord. In this case, I used a square knot:
Perhaps not a necessary step, but I took a lighter, and "welded" the knot:
Push the knot inside the PVC.
The finished product:
Gratuitous photo with my BK2, with modded sheath:
http://www.bladeforums.com/forums/showthread.php/845352-BK2-Sheath-Mod.-Extremely-Photo-Heavy
This is a very easy and fun project, and well worth the little time invested.
