If customers and collectors request stabilized wood, yes.Walking Man said:Is it REALLY necessary to send your wood away?
<snip>
A)the pieces that are needed to make a knife aren't really that thick and
B) Even if the knife isn't stablized all the way through, the knife is still very well sealed, not allowing moisture in or out, which is the main cause of warpage or shrinking right?
I just read the tutorial and it did not mention moisture content. In my opinion this is a serious flaw in the process.schwartzbunt said:What about this Tutorial from NorthCoast Knifes![]()
Vacuum will cause water to evaporate.R.Coon-Knives said:I could be mistaken here but I believe that when you put water under vacuum, it boils off because of the low pressure.
Interesting! I didn't know antler needed to be stabilized,is that true even if the horns are well seasoned,dried and years old,I only ask because I have about a dozen sets of racks,mostly white-tailed but two nice muley racks.Don't forge or even stock removal,buy blades and guard and handle them.Anywho,handled one in mahogany and set up a jig on saw to cut horn slabs in half and inset/inlaid them in the wood,just drilled them and pinned them to the blade.One pin through the horn slabs and one pin in front and one pin behind the inlaid horn.Turned out OK but nothing I'd post pics of in here.Thanks.Nobleforge said:I'd never try it in a million years.
I send ALL my bones, antler and and wood to Mike at WSSI. He's THE man!![]()
