How would you sharpen a chisel that isn't straight right at its edge - if i placed only the edge touching a flat bench light would show right under the edge.
At this point would the only way to straighten that edge be by grinding the edge 90 degrees it till its flat, then progress from low grit to medium?
I also have a similar issue where the bevel in some spots are 9-10 degrees and the other end is 11-12 degrees (judging from the shoulder of the bevel not being straight). How would I take off that high spot down from 11-12 degrees to 9-10 degrees? My method that I "tried" was to lift up the end with the 9-10 degree bevel so that it doesnt touch the sandpaper, sanding down the spot that is 11-12 degrees. I believe that this will create some unevenness unless I somehow am able to flatten the high spots and low spots till its level.
