Nextcity, First use a deglazer to remove the surface sealant, then you can re-dye black. All of my black, I start off with a blue under layer, this gives a deeper black and requires less black in the end. Most after market blacks have an issue with leaving surface particles of the black pigment if you use too much. Had to replace the drivers seat of a Lexus after using too much black on a customers belt. rtmind/randy
Tandy Eco-Flo All-In-One Leather Finish, Midnight Black
You can also use Vinagroon if you want to DIY. But, it can be a bit smelly....
Best bet is probably commercial dye as recommended. There may he areas with glue that won't be as black.....
