I've not tried any of these teqhniques, but, there's always some media for scouring or removing or polishing. For example, there's a certain clay that removes the sheen from new baseballs, the umpires in Major League Baseball use it on every new ball.
I'm guessing that something like soft scrub, dirty hands, some type of car buffing wax, or a similar polish could do it. Certain polishes work on car's clear coats only when the speed of the buffer is fast enough to create heat, and move the clear coat. Yet, if you just rub it on by hand, it will "dull" the clear coat.
There's a way to do this, and I suspect CWL is correct with his hairdryer solution. Heating the wax will loosen it enough to be moved away.l Just be careful, don't overheat the epoxy in the micarta! Micarta can start to fall apart in dishwashers for example.
