How to undo or weaken threadlock, HELP!
trimcut123
BANNED
I just got a knife from a trade with tons of red threadlock on all the screws. Its a para mili. Does anyone know any expert tricks on how to loosen or weaken the threadlock so i dont strip out all the screws or break my tools,?
thnks
matt
zerochance@sbcglobal.net
Apply HEAT to the tool that fits the screws and some of the heat will transfer to the screw, then try backing it out, a sharp tap on the screw while hot may also break it loose. Nothing ventured, Nothing gain, done this on manufacturing equipment but never a knife.:D
thank you james i will try that. If all fails how can i get the screw out without damaging the back spacer so that i can put new ones in?
You can put a soldering iron tip on the screw, heat it, and immediately back the screw out.
Bill
The soldering tip idea is a good way, G-10 is designed to take heat (be careful still). Also try soaking it in boiling soapy water, this will clean your knife real good as well.
