Bill DeShivs
- Jun 6, 2000
I guess I've stirred up enough stuff about sharpening.
Here is a tutorial on how to do it. It dosn't matter what kind of stone you use- diamond, India, Arkansas, ceramic, water, even Carborundum-as long as the stone is reasonably fine grit. The finer the stone, the slower it will cut, but the sharper the edge. It seems like most of you guys have tried all the jig-type sharpeners, so why not give this method a try?
The stone should be level, and secured to a flat surface. Pull or push (it doesn't matter) the edge on the stone at an angle (15-20 degrees) keeping the angle consistent. That is the hard part. Turn the blade over and repeat. Alternate strokes. Don't do one side at a time. Repeat until sharp. If the edge feels rough,you need to repeat with a finer stone. Don't press hard. Get a feel for the cutting ability of the stone. As the edge approaches sharp you can lighten your strokes.
DO NOT LAY THE BLADE FLAT ON THE STONE!
Practice on junk knives until you have the technique down pat. The blade should be sharp and not scratched. More to come.
Bill
Bill
