I have a 6" inner diameter forge with a 2" muffle centered in the forge propped up on thin slices of firebrick. It's not attached in there just resting on the firebrick so the flames can swirl around it.
My question is how to use a thermocouple with this? Should I drill a hole between my two burners through the side of the forge and then a hole in the muffle for it to fit in?
My concern is if I permanently seal the thermocouple on the inside of the forge if I will be able to get the muffle out. Is there a good way to just "plug" the hole in the forge so I will be able to move the thermocouple in and out if I need to replace or remove the muffle?
Thanks for any help.
