How to use insert image in thread???
trying to put images up in a add i put up, but it keeps telling me upload failed. can someone help me pls. are there size limitations or something?
You need to go to Paid Subscriptions to update your membership level. You can neither post images NOR post an ad in the Exchange unless you pay for a Gold member fee.
That's the deal! Welcome. It's worth it.
My active subscription says gold, i was able to post the add in the for sale section just couldn't get pics to upload, trying to use imgur right now after reading the sticky above but am still having trouble figuring it out grrrrrrrr.
OK. Mandrew8 you need to go to the Subscriptions page and update your status to GOLD. If you paid, you are eligible. It does NOT update automatically, I see this all the time.
Maybe that's the problem? Your profile avatar shows you are still 'registered' only (as I write).
Here's a test from me to see if attachments are still working through the BF system (Which I rarely use because I use an outside host Fototime.com)
That your photos are GINORMOUS is a clue. I think there are presizing conditions which need to be met before you can post through BF.
For instance the photo I uploaded below is less than 100kb in size. I don't think you can simply add images here without resizing FIRST. Sigh....
And, it appears you need to do so through Imgur.
attachment.php
Jim
goto image sharing site
postimage.org
imageshack.us/
etc
upload your photo. copy the URL that says direct image
paste url you copied into post.
add img tags
Code:
[img]URL LINK HERE.JPG[/img]
One of the things I did to learn a lot of how this worked was to quote someone who had just done what I was tryin' to do. For example I had the hardest time figurin' out how to post videos till I started copyin' the post that had the results I was tryin' to achieve and postin' it directly above the link and below what the function icon was. When I had the 3 in line for comparison I was able to see the differences between what worked, what the computer software said to do and what the unadulterated direct URL is.
Dependin' on the device you're enjoyin' BFC on and or the current status of the forum's software, (features disabled while troubleshooting) sometimes what's in between the tags doesn't always work. I've gotten so used to typin' it out and just insertin' the appropriate URL between the right tags that I find it quicker that way and other than the basic text commands, no even those, cntrl b for bold, cntrl c for copy I type out instead of usin' the command shortcuts.
The point I was tryin' to make was that just by seein' how somebody else does it where it works and comparin' it to what you do that doesn't work, figure it out by noticing the differences. There used to be many posts on the tech support forum that talked new members through the most common FAQs I haven't looked but I'm pretty sure there's a sticky somewhere on how to deal with almost anything relating to postin' or attachin' a pic or file.
