- Feb 24, 2014
Robert, pre-tensioned clips are better for videos for a number of reasons. Under 100 BESS the clips score the same as the BESS-certified test line anyway.
So the BESS thing is still being used?
Yep. What do you use?
My thumb, lol.
I score in the teens or less on a BESS with my normal edge so for me its a bit inaccurate.
Pad of my thumb and "feel" the edge, like a Carter three finger test but with one finger. Place finger on edge and let it bite a little by moving your finger. Not enough movement to see, just to feel. 30 years of feeling edges this way and I can tell you things about a cutting edge most would need a microscope for.
If it's not a trade secret what is your sequence to get that level of sharpness?
Really sharp is when you see blood before you feel the cut.![]()
I keep a few of those at all times, but usually do feel the ones that bleed.Or even when you don't see blood. I found a slice on my right index finger yesterday that I didn't even know was there. It wasn't deep enough to bleed and I didn't feel it when it happened.
How am I supposed to show sharpness in a video by a finger feel?
Under 100 BESS the pre-tensioned clips and BESS-certified test line score the same. E.g. Mike Brubacher scores on a new Gillette razor 50 BESS and Feather razor 30 BESS using the test line - and the same they score using clips in testing done by Chase Anderson at Refined Shave https://www.refinedshave.com/razor-blade-sharpness-testing
My tests of knife edges under 100 BESS show negligible difference of 1-3 BESS between the line and the clips. I start seeing a tangible difference between them on edges that score over 120 BESS.
The pre-tensioned clips are better for documenting events in a video, because rule out falsification of the sharpness score by over-tensioning the test line.
The Victorinox SWIBO Chef's knife in my video is sharpened at 12 dps and shows 61 BESS before and after the 2kg impact, and this is really impressive how strong a cleanly deburred edge is.
We filmed this episode by a single long shot.
A new Gillette razor scores 50 BESS, but of course is nowhere near as strong as the knife edge.
Key to the edge longevity, to the lasting razor edge on your knife, is to clean it of all the metal deformed in grinding.
My thumb, lol.
