How will flux effect your blade?
I have noticed a brown stain near the solder on the blade and guard I an not sure if this is rust or flux seeping through.If it is flux,how could this adversly effect my blade?
Thanks,John
If it is flux it will rust!!!!!!Take it from experience.Try cleaning it off,if it is rust it will leave a groove or pit in the blade.If it didnt leave any pits then it is safe to say that it is flux,neutralize it with window cleaner with ammonia in it,then put some wet baking soda on it this will help to finish neutralizing it.Sometimes you can get a bubble trapped inside the joint and it can leach out for a long time if not neutralized....Hope this helps,Bruce
The Soul of the Knife begins in the FIRE !!!! Akti # A000223
Use TIX solder. It melts at a low temp., it is extremely clean, doesnt stain with time, and works very well at low heat.
Uncle Al Knifemaker Supply sells it, along with a few others i believe.
Matt.
"Eternal vigilance is the price of liberty"
Thomas Jefferson
www.lameyknives.com
So the ole bucket full of water and baking soda mix doesn't work???
Always think of your fellow knife makers as partners in the search for the perfect blade, not as people trying to compete with you and your work!http://www.nebsnow.com/L6steel
Buzzards gotta eat, same as worms!!!
