How would you finish a San-Mai wrought iron and 1084 blade?
I found an old buggy wheel like 40 years ago. I finally decided to do something with it. I forge welded a 1/4" piece of 1084 between two 1/4" pieces of the wrought iron buggy wheel. I then put a ladder pattern in the blade. Today I did the heat treatment. I can see the ladder pattern in the blade, and it looks pretty good.
I am thinking I will need to etch the finished blade to bring out the contrast between the 1084 and the wrought iron.
Anyone have experience with this?
Definitely etch it, using ferric chloride. I've made a few wrought iron, carbon steel core san mai blades and it's one of my favorite mixes, especially when using a layer of nickel sheet in between. :thumbup:
~Paul
My YT Channel Lsubslimed
... (It's been a few years since my last upload)
I agree on the nickel between the two. It makes the weld easier and stops carbon migration to some degree. It looks like a hamon when finished.
Grind and sand the knife to its finished size and condition. Etch well in FC and neutralize very well ( WI may have pits and pockets). Re-sand lightly with 1000-2000 grit paper and put on the handle.
Thanks for the help. I etched the blade in muratic acid and then neutralized with windex, then blued the blade. I am pleased with how it turned out. This was my first attempt. I learned a lot.
Came out good Tom.
Just plain ole muratic from the big box store? How long did it soak?
Dozier
It was muratic acid from Lowes. I left it in 30 seconds the first time, took it out dunked it in water and scrubbed with 0000 steel wool. The second time I left it in one minute, dunked it in water, scrubbed with steel wool, then sprayed with windex. Then I applied Birchwood casey bluing for one minute, then under running water scrubbed it with steel wool.
DO NOT use Muratic acid in doors. DO NOT breath the fumes. I etch outside with a breeze blowing the fumes away from me.
Next time I think I may etch in FeCl after the muratic acid.
I took a ABS Damascus class at Washington Arkansas back in 1991. The instructor was Master Smith Charles Ochs. He used Muratic acid to etch the Damascus steel and that's what I use for Damascus. For etching W-2 with a Hamon I use diluted FeCl.
A few weeks ago I etched some Wrought iron guards in FeCl and didn't see that the etch did much good. Maybe I didn't leave it in long enough.
Hey Stacy, i've heard a lot about using nickle. Do you mean using a high nickle steel like 15N20, or a sheet of pure nickle?
Pure nickel 200 or 201. You can buy foil on eBay usually and jantz has particular sizes of plate.
Tom,
I hate screwing around with harsh chemicals like that! :barf:
When I etch carbon steel Damascus I simply use White Apple Vinegar. It takes longer, but you can do it inside and dump it down the sink when you are finished.
I put the blade in, check it every 20 minutes or so. If I want a deep itch I leave it in over night. When I want to stop the process, I Just squirt it with Windex Run hot water on it and squirt it again. Then dry it carefully over an open flame.
You just didn't leave it in long enough! :D ;)
Here's some Wrought Iron/L6 (bandsaw blade steel) san mai that I made a number of years ago which ended up having an inclusion/delam in the wrought iron itself. Since the inclusion happened to be near the center of the billet, I just cut it up into a few smaller pieces to mess with some other time, and ended up making this little kiridashi from one of them. I put it in my FeCl, but I accidentally forgot about it until the next morning, so it had a good night sleep in there lol... But yea, it ended up being a "happy little accident" :D because I really like the way it looks :thumbup: . I do plan on making a normal edc sized, "naked" (no scales) blade sometime in the near future. Next time however, I will put a resist around the spine, which will be nicely rounded off.
~Paul
Coldsteelburns, I think you are right I should have left it in longer. Also I think I need some new FeCl. I plan to make a new one in the near future.
