Cliff Stamp
BANNED
- Oct 5, 1998
Does anyone know the hardness specifics that Clark obtains on his blades? Is the entire blade Bainite, or just the spine?
-Cliff
-Cliff
Modern Tool Steel (Crucible Champalloy or L-6). I make these blades for the martial arts enthusiast who wants performance and durability first and foremost. A thoroughly modern steel, it is given a proper Japanese sword size and shape for the correct feel, but there is where the similarities end. The heat treatment is strictly twentieth century, and provides a blade that has a body which is very springy at HRC 48-50 and a hard edge that is HRC 57-58. The result is a blade that cuts well, holds a good edge, and flexes instead of bending if the cutting stroke is not so good. They CAN be bent if sufficient force is applied, but it takes a great deal of energy to do so. (CC's translation "Get your cheater bars out boys. Long ones.") The hamon is not as "active" with this material and heat treatment. Under any semblance of "normal use" these blades will never bend and take a set, nor will they chip. If "tough" is what you value the most, this is the blade you want.
Representative example of what the hamon looks like on these blades.
L6 is no longer available as a blade only item. (effective July 6, 2001). The L-6 katana are now available exclusively through Bugei Trading Company, and only as a complete, finished sword, no more L-6 bare blades will be offered for sale.
Originally posted by FullerH
Wouldn't R57-58 be inclined toward chipping in a sword usage? I guess it might depend upon the steel, but that seems pretty hard for a sword edge.
Historical katana will often have edges exceeding 60RC, being full-hard and often times without stress-relief after quench. These blades were somewhat prone to chipping when they were used improperly, but then there were also truly great swords that had very hard edges that stood up to a significant amount of abuse.
Hardness is just a number in general...
