Thanks for the link DWRW.
Do you strip the tang that is sandwiched between the micarta or leave it krinklecoat?
I don't strip the tang that is "Between" the micarta
...., but you probably mean the exposed parts of the tang
Yes. I personally do. I think it looks nicer....
But, I don't think you have to if it doesn't bother you and it would be a lot easier when the time comes to sand and buff things up.
I think a pretty reasonable argument could be made and justified for leaving it if the knife is to be a user and if the look doesn't bother you.
Removing the coating from the "blade" specifically has "some" slight functional benefits - "Especially" in smaller knives. The coatings can cause drag on the blade when through cutting and the knives just won't cut as well if the cutting involves material contacting the coating (through cutting).
There is no "functional" benefit for removing the coating around the tang or even the choil. The only benefits would be aesthetic preference.
Side note: Similarly, there are improvements that can be made to the edges of the Busse family of knives for cuttings tasks. ** But, it depends on what you are cutting and using the knife for.
If chopping, I would still argue that improvements could be made to the edges. But, there are compromises in what you can do to an edge. If the edges are thinner and with less shoulder transition between the edge grind and primary grind, then the knife will cut better. If the edge angles are very obtuse and thick like most Busse family of knives, they won't "cut" as well, BUT, they are "Tougher". I hate compromise, but it is always there.
There are compromises to removing the coating.
To me, there are only two justifiable reasons for having the coatings on the blades:
1) Help prevent rust.
2) Help keep costs down.
A third that doesn't apply to me is: some people like the look. - I don't like the look.
In regards to rust: I hate rust! But, I would rather maintain my satin blade than have a coating.
In regards to cost: I am more than happy to pay an additional $15 - $30 for a satin blade. It shouldn't cost much more than that. About 90% of the blades sold in the world don't have coatings and short of full custom knives they almost all cost less than the Busse Family of knives.
Historically, Swamp Rat and Scrap Yard don't seem to have charged rediculous prices for Satin / LE models. But, some of the Busse satin / LE models are $100 - $200 for a satin finish!!! :thumbdn: :barf: - That is REDICULOUS!!!!!
.... but, apparently some people are willing to pay it. Not me!
* I vote for more satin and LE finished knives from Swamp Rat and Scrap Yard, but at more reasonable $15.00 - $30.00 premiums.
I have stripped a bunch of knives and it is not all that hard, but it does take some time and a fair amount of time to get it looking decent.
I would MUCH rather pay Swamp Rat and Scrap Yard for an LE version.
They can do it WAAAAYYYYYYY Easier than we can and WAAAAYYYYYY Faster! Plus, they wouldn't have to actually put the coating on!
So, I wish they would provide LE models much more often! :thumbup:
I don't know why they don't. But, I am certain they would please more people by offering satin versions of everything.
I have found that the chemical stripper does not affect micarta or Res-C (or at least I can't see ANY visible affect and I have looked hard.)
Also, I use a gel stripper and the gel stripper doesn't really seep between the micarta and tang. I would rather not remove the coating under the handle to help prevent rust and because that layer of coating probably keeps the scales tighter on the tang.
So, I just brush the stripper all around the exposed tang.
Again, getting the coating off is VERY simple.... it's the sanding afterwords that can be a bear.
Mike said the coating will start to bubble in a matter of seconds - this is true.
But, what I have found to be the best for me is to put a fairly even thick coating on and let it bubble till it stops bubbling. This usually seems to take about 7 - 12 minutes.
If you start to scrape it before the chemical is done, you will just have to re-apply. If you put it on too thin, you will have to re-apply.
I just stand and hold the knife outside so I can have fresh air circulation - I don't want to breath the fumes - It is actually not nearly as strong as paint thinner because of much slower evaporation, but I still don't want to breath the stuff.
*** The last one I did I was able to take of the coating in one single big black sheet. It was pretty much falling off.
:thumbup:
That was on a Res-C Yard Guard...... and no exposed tang.
Still removing the coating from the exposed tang is very simple as well.
Sanding and finishing the exposed tang at the spine and belly of the handle is simple enough.....
*** However ***, sanding and getting a decent finish around the guard, choil and especially the lanyard hole is tedious! :grumpy:
I should also mention that many people have used 3M abrasive wheels to buff and polish. These may have some advantages around the handles (???) and possibly on the handles (???), but I haven't used them yet.
Same rules would apply about using different grits.
