- Jan 21, 2000
Over the past 6+ years, I've commissioned several knives in this hunter pattern from some of the most talented makers in the country. I've received some beautiful interpretations and some great, great knives along the way--I appreciate every knife and every maker for his interpretation.
Stuart's first rendering of the pattern over a year ago was the most faithful to my sketch of any I'd received to that point, which was impressive considering all the others were from master smiths. I told him if he ever wanted to make another, I'd like the chance to get serious about attaining my "ideal"; by adding some tweaks and additional measurements into the mix on handle thickness, contours, etc.
Early this year, Stuart said he had been thinking about doing another one, and of course, I got very excited. As we began discussing particulars, I remembered that a few years ago my good friend Phil Wilson offered to heat treat a CPM blade for me if I ever needed one, and in my mind this was a perfect opportunity to call upon the "Wizard of CPM" for that blade. Stuart agreed to give S90V a whirl if Phil would do the heat treat, and the project took off.
I just received the knife from Stuart and this is the closest I can imagine to my mental ideal for the pattern. It is simply amazing to hold my actual "idea" in my hand, rendered in desert ironwood burl and CPM S90V, heat treated by Phil to 61-62 HRC:
On top of my original sketch:
The knife is just high enough off the paper sketch in the above photo to make it look slightly larger, but the dimensions of sketch and knife are exactly the same. I asked Stuart to make the ricasso and guard just a tad longer than the sketch, which he did perfectly.
Handle contours bright lit:
Stuart:
Thank You, my friend. As you know this beautiful, supremely functional package fulfills a very special quest for me. In your eyes I know it's not perfect, but it is to me.
Will
