- Oct 27, 2005
Here is my latest knife. This is made from a file (W2 steel), via stock removal method. The blade surface is jeweled and then blued. The bolster is brass with gun bluing also, to give it an antiqued look. The black pin look is black epoxy 3/16" deep into a hole with brass pins inside. Basically, I countersunk the brass pin holes and filled with black epoxy for a nice offsetting look to the brass. It's a very dressy look. The handle is Cocobolo Rosewood. There are 24 3/32" brass pins altogether, and the four mosaic pins. The handle is very secure. I finished the cocobolo rosewood with teak oil (4 coats, with hand buffing after each addition). I then polished it out with 2 coats of Johnsons Paste Wax. The sheath is my second sheath ever.
