Recommendation? Husqvarna vh5 into kitchen knife.
My dad gave me an old Husqvarna vh5 14" concrete saw blade and I am attempting to make a kitchen knife from it I have already cut and ground it to shape the spin is about .08" thick and tapers to .02" and it is 2" wide at the heel to 1.75" at the tip. I'm new to knife making been at it as a hobby for about 5 years now. I recently bought a forge but I can't really use it because of where I live so I'm having a hard time trying to harden this blade. Should I continue with this project or trash it and move on. I have done some research on the steel and it seems pretty crap.
Welcome Scot.
Fill out your profile with where you live and something about you. It will help with answers and a nearby maker may offer you some steel or spare equipment.
The concrete saw blade is made from mild steel with carbide or diamond teeth. It will not make a knife.
The Count's suggestion of 1080 or 1084 is a good one. These steels are readily available from the knife suppliers like USA, Knife Supply, Alpha, Jantz, Texas Knife Supply, etc.
Welcome Scot.
Thank you for the feed back. I actually do have a bar of 1080. I'll mark this as a practice piece.
The general consensus is to use a piece of hardenable steel as practice. 1080/1084 costs about $10 for a 1-foot bar.
If you practice on junk steel and it comes out nice you have nothing.
If you practice on good steel and it turns out nice, then you have a good blade to HT.
After HT you will get to practice finishing up a hardened blade.
If that works well, you can put on the handle.
If that works well, you have a nice knife you made yourself.
Thank you I appreciate the input. That being said I have done my homework and I do understand the basic fundamentals of knife making, but out of eagerness and boredom I used the saw blade my dad gave me before doing research on it, and instead of putting it off as a failure I'd rather put it as mild practice, being that I do not have the funds to waste good steel and sometimes I'd rather put in the time to do a mock up before possibly messing up a good piece of steel, now I have a stencil made from mild steel that I can use to outline on to good steel.
Scot -
I agree that the practice wasn't exactly wasted, and I understand your attempt to be frugal, but you probably spent more on doing the "mock up" in belts and such that the cost of a piece of 1084. For many people, time is also a valued commodity. The following is not meant to discourage you, just a comment on the costs of knifemaking.
If the cost of $10 for steel is prohibitive, get out now while you can. Knifemaking is not a cheap hobby. Knifemaking requires continued replacement of steel, belts, sandpaper, handle material, rivets, adhesives, hacksaw blades, heat treatment costs, and other small tools and items. The equipment is not low-cost either. It is often a rabbit hole of buying more equipment and supplies. The piece of steel used is usually a small part of the final cost of a finished knife.
While knifemaking can be done with files and sandpaper plus a propane torch, that won't necessarily make a very good knife (unless you have the skills and experience already).
It is not uncommon for a new knifemaker to spend $5000 in their initial setup of equipment and supplies.
There are two knifemaking jokes that are mostly true:
Knifemaking is the best way to spend $5000 to make a $100 knife.
The way to make a million dollars in knifemaking is to start with 2-million dollars.
