- Oct 10, 2003
I'm not a hydraulic expert; but I have been through many in my 35 years of farming. I want to share some basic information about hydraulic design for presses, rolling mills, really anything hydraulic.
The power source is the starting point, electric or internal combustion.
Roughly you need Two HP Gas to One HP Electric.
How many AMPs do you have available/ You can by with a 50 AMP breaker on a ten HP load if you split the start-up with 2, 5 HP motors.
Using 10 HP Electric you can push 8 GPM at pressure, for this example at 2000 psi. Your pump must be balanced to the motor for efficiency. If you have a power limitation you might have to consider a more expensive two stage pump. Your free travel speed is often times about 4X the working speed. You can run a 16GPM two stage if the second stage is 4GPM or less on a 5 HP electric. You get .8 GMP for every HP.
Some quick numbers; A 5 inch cylinder has a moving face on the piston that is 2.5 squared times pi. equals 19.6 sq in. A 6 inch cylinder has a face area of 28.3 sq in. 2000 psi is a ton. A 5 inch cylinder at 2000 gives you 19.6 tons. A 6" cylinder at 2000 psi gives you 28.3 tons. The larger the cylinder rod the more stable and more durable. The area or the face of the rod must be deducted from the area of the cylinder to calculate the pull pressure.
A GPM is about 230 cubic inches per min. About 4 cu in per second. You need About 4.5 GPM to move a 5 inch cylinder an inch a second.
Surplus Center catalog has about a 1/2 a page that is dedicated to hydraulic design, it is very good information.
In Press design consider a push up or a pull down, either one is much shorter than the top heavy push down designs. This allows for more stroke and higher die location. To do good forging you will often need to have your eyes at die level, for me it is easier to lift the billets a foot or so higher once than to stay bent over. I work billets in the 10-25 pound range. The longer the mechanical engagement or slides in comparison to the width the better the mechanical accuracy of opperation. H Frames are more accurate with the least amount of steel in the construction. I like a four post frame that can stabilize die travel on two axis.
All this stuff is intuitive and logical, and my experience...Ed
