DaQo'tah Forge
Banned
- Aug 26, 2002
Hypothetically speaking of a new tool I would like to own...
This is going to seem like I got way too much time on my hands, but I have had this idea for a hypothetical knife making tool for a for a long time now, and I have decided today to toss my idea out onto forum to see what others think.
A Roller-press......any such thing?
a press that has some rollers to squeeze the hot steel thinner. Thats my idea for a new type of knifemaking tool. Here is behind my idea.
For the last few years I have been fooling around trying to make High-performance knives . I have been using 52100 steel I get from Rex Walter, but I have always wondered if it would be possable to make a High performance knife from two different steels at the same time?
Now 52100 is a good steel for a blade, but what it is mostly known for is that it seems to have the ability to be both strong, and hard when you heat-treat it correctly,,,
But there are other steels that are stronger right?,,,,
And there are other steels that get harder correct?...
What if we made a blade from two different types of steel?...a steel on the outside of the blade that gets very very hard, wrapped around a super soft strong steel......http://daqotah.tripod.com/id2.html
Now most of the pro bladesmiths use power hammers or a big hydraulic press, but I would like to see someone invent a roller-press,,,why, you ask?, heres why.
In The Bearing to Blade Video by Ed Fowler , we learn that when the 52100 steel is turned into bearings at the foundry, that the raw hot steel is "extruded" in such a way as it forms a grain pattern in the steel. Ed Fowler in the video shows how he etches the ball bearings to identify the direction of the grain, and then works to push the steel with the power hammer in this same direction.
I was thinking that a roller-press would do this better, the bar of hot steel would be somehow moved back and forth between the rollers, that look something like the old washing machine rollers my Grand mom had on her old washer to wring out wet clothes.
The roller-press would squeeze out the hot steel the long way with the grain, and there would be no violent smashing of the steel in all directions as happens under the power hammer.
this more gentle yet more constant force applied to a sandwich of two different steels would help weld way better than striking with hammer blows, don't you think?
