- Sep 11, 2009
I believe in the power of a chisel scandi grind.
I was skeptical about a chisel grind on a bushcraft knife,but thought with the grind on the right side,it should work,so I snagged this little beauty from Daniel when he put it on the Ex.
Happily,it was waiting for me when I got home last night.
I ogled & fondled it till I couldn't stand it,I had to try it out.I grabbed a mesch. rod & threw a few sparks using the spine,then made a feather stick.So far so good,so I put it up for the night.
I awoke to the sound of rain pitter pattering on the window this morning & after checking the weather I see it's supposed to be like this all weekend,bummer.No playing outside for me & my new knife.
Luckly I have a fireplace in my aptartment & plenty of wood to test it on.
I first battoned a hunk of firewood down to a manageable size,then drilled a couple of divots for a bow drill spindle,then made a couple of notches,then some feathering.No problem for this chisel scandi knife from Daniel.
It slices & drills with the best of them.
I then used the exposed tang to strike some gobs off my mesh rod & got the feathers to ignite.
Woohoo,fire!I will survive,hallelujah I will survive!
Thank you Dan,you made a believer out of me!
& I look forward to my next one.
