- May 12, 2010
I cannot drill this in a house
I cannot drill this with a mouse...
Ok, sorry but I'm at my wits end. I have a piece of 15N20 from Aldo, only .05" thick (not a typo) and I can't drill holes in it. At this point I've spent more on drill bits than the damn steel is worth.
I don't have any high end bits like tungsten carbide, but have tried all the flavors available at the local hardware store with the same results. I get halfway through, so lets say .025" and then the bit stops cutting.
I've tried with oil and dry, same result. I've tried max speed on the drill press, to the slowest setting and several in between. Played with tbe tension on the drill press belt.
The steel cuts just fine on the bandsaw and a file bites it easily so I don't think it is hardened. And the half of the hole that the drill bit cuts, goes in real easy, just like all rhe other steel I've drilled in the past...but then just stops cutting.
Thanks, guys. I'm probably going to slap myself when you tell me some common sense thing Im either doing wrong or overlooking.
