It might just be too big for the lanyard hole but you might try this, tie a string to the lanyard, drop the string through the hole and pull it through.
Ahh, hadn't seen that on my travails, cheers.There are two main types of paracord used for lanyards. 550 is the standard. But there is also a thinner type also that seems to be used on Amazon in which the loop is made from 275 size para while the body of it is 550. I believe it’s for that very reason. Don’t have a link at the moment and not sure if we’re supposed to link to Amazon either. If I run across it I’ll dm the link.
