I think there's some confusion concerning terms here.
I solder, braze, weld ... you name it.
Just to be clear, when I talk of soldering in this context, I'm not talking about using a soldering iron, but a torch--the way jewelers solder. This might look like brazing, but it's really classic hard-soldering technique.
There is good advice offered above. I don't think there's any reason to use 1100 F solder for this application, and braze is usually thicker and wont penetrate and flow into your joint like hard soldering. Hard soldering produces a very, very strong joint.
I like a low temp silver-bearing solder from Brownell's (around 550F or so), but that's pure personal preference. I have used IT solder (which is over 1000F) and think it's a waste. The 550F stuff is plenty strong if you're going for some added mechanical strength, and pretty bright like silver solder.
I assemble the knife in a vice with the point up. If the fit is what is should be, it should be a stable-enough assembly so there isn't any other clamping. I just clamp it in so that the vice jaws are closing on the FAR edges of the guard-- as far away from the area to be soldered soldered as possible--the blade and joint area are suspended in the air.
If it's a strange-shaped guard/blade and there might be instability, I'll peen a section of the tang so that the guard presses on with some resistance and stays in place. Worst-case, I'll tack it from underneath with TIG.
You want a decently hot-neutral flame. If I'm doing 550F solder or softer I'll use MAPP gas. You want to do this operation fast and not heat the part more than necessary. If your flame is too hot, you'll cook your flux off and have problems.
I'll dip the end of a welding rod into the liquid flux and touch it to the joint. It will wick in pretty fast and clean without getting all over the guard. The solder follows the flux and doesn't like to stick where there's no flux.
With solder in hand, heat the guard from UNDERNEATH. NEVER-NEVER FROM THE TOP. Rather, with the flame under the guard, Repeatedly touch the solder to the joint from the TOP. The joint will heat up fast and the solder will--all of a sudden-- wick in just like the flux did. It'll take about one second to zip all the way around and all the way through between guard and tang.
Remove the flame IMMEDIATELY. If you overheat the solder it will tend to flow through the joint and give you a concave appearance and voids. Done correctly, there shouldn't be any need (except under unusual circumstances) to use heat shield since the process is very fast so you aren't heating the heck out of your workpiece.
I usually clean up the joint line on top of the guard, if necessary, by cutting the excess off with a big, flat graver. It should be very minimal.
I think this process is basically what the others are referring to when they speak of soldering. Again, a good silver solder joint is tremendously strong. This would be the typical process for guards, fittings, etc.
