I don't understand Benchmade's Teflon coating.
Ok, they put teflon coating on their 710HS and 806D2 so that they will have better corrosion resistnace right? But if you actually use the knife then the teflon just wears off anyway. So what is the point? I would rather have a satin finish 806 that I have to take care of, than a Teflon coated 806 that is scrapped and "satin" finished where it has rubbed what it was cutting that I have to take care of anyway.
Basically, what is the point of coating the blades with something that is going to come off when you start using it?
I guess some people like the fact that teflon blades are smoother opening, although my plain jane BM;s are as silky smooth as a guy could ever want. I dig satin finished steel too.
The boron carbide that BM uses does look absolutely kick a$$ though!!
anyone who has a 710HS or 806D2 please chime in. Do the blades really have much problem with corrosion where the teflon has worn away? I'm trying to decide if I should get one of these, or instead get a plain-jane benchmade axis with the 154cm such as the regular 710 or the 735
Well... I really don't use my 806D2 to cut anything at all. The most cutting this knife sees is opening letters and when I do sharpen it... I am very careful. I bought this knife as self defense piece. If I want to use my knife hard I will use my Satin Griptilian or my Spydie Dragonfly!
Well I have a BM 804 AFCK M2 (very similar to the 710) and all I can say is it stays very sharp when it shouldn't (gutting and dismantling deer) and is much more corrosion resistant than CS's Carbon V. No I have not had problems with rust where the BT2 finish is starting to wear off but I would fresh water rinse and dry after cutting anything acidic such as limes for the Coronas' when this ball shrinking weather breaks.;)
BM says that the coating still protects even after the coloring comes off. I guess the color is just a part of the coating and there is still some kind of clear coating or something left.
Well what db says is correct, essentially. In that despite noticeable wear/scratches etc to the BT2 finish after use, a sufficient amount of it will remain on the steel to continue to do its job - corrosion resistance and enhanced cutting smoothness (arguably). Even after significant, prolonged use. In other words, what the eye sees is misleading in a sense - the coating is still there.
If you want to know more about this, take a look here -
http://zvis.com/knives/folding/bm710ax.shtml
There are some photos and other links there of interest, including a prior thread here.
All that said though, I like many do not find the BT2 finish appealing, for a number of reasons (see what Joe Talmadge has to say about it in the thread I refer to for example). For one thing, I don't like the visual appearance after use, despite the coating still being effective, or even before any use at all for that matter.
I will always prefer a plain steel, uncoated blade. But for steels with high corrosion concerns like M2, it is pretty much certain that BM will only offer them coated - either BT2 or BC1 presently. Ideally, you'd have a choice, in which case mine would be the latter for sure. For reasons of production economics or whatever, however, that isn't the way it is.
The last Forum Knife BM produced was a 705 with M2 steel and BC1 coating. A really great knife. Also, you could say it indicates that quite a few BM Axis lovers have the same preferences in relation to all this.
D2 is pretty darn close to stainless anyway, it takes a decent amount of neglect for D2 to rust in most area's.
I have an 806D2 with maybe 8-10% of the finish rubbed off and probably 6 other D2 knives with no finish - no rust problems and I use them from everything an knife can be used for with no special treatment.
M2 is a whole nother animal though - it is much less rust resistant than D2.
my cammilus maxx "spots" easier than any other knife i own and its D2 i think...........never bad stuff, just "discoloration" but i dont really use it much either, so
greg
I always thought of black coated blades from a tactical aspect. The black blades don't reflect much light, and in the dark they're very hard to spot. At least thats what i thought one of they're intensions was.
