I dusted off some vintage Micarta
Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
I dusted off some vintage Micarta over the holidays to do a special run of Field Knives
I usually avoid fancy scales materials, particularly on field grade utility knives, but I had some requests and it was an excuse to go out into the shop when I was supposed to be on "vacation".
I also wanted to try out some Terotuf and denim micarta
a.jpg~original
b.jpg~original
c.jpg~original
d.jpg~original
e.jpg~original
Terotuf is a little bit ugly and unstable, but it's wonderful for scales on hard working knives because the way it performs when your hands are wet and sweaty. I laminated it to a thick micarta liner to reduce issues with it shrinking and exposing tang.
The denim micarta is actual Norplex Micarta. Norplex bought the name from Westinghouse but mostly imports material. My supplier assured me this was domestically produced and I wanted to try out a denim reinforced phenolic. It's laminated to a thin G10 liner.
There is no more vintage Micarta sheet anymore, but you can find drops, remnants, finished parts and odd shapes. These require some processing to make into scales.
The dark brown micarta came from an old stock round bar. I don't think it's dyed brown, I think it's just really old, and because it was turned the resin rich surface that seals out oxygen was missing so the darkness penetrated to the center of the bar. The canvas is yellowed. I could be mistaken, but I don't think its appearance is going to change much more over time, I think this is about as dark as it's going to get. I believe this material might be older than a lot of the people on this forum, but it's lineage is unknown. Its pretty though. I cut this piece to have edge grain rather than flat. Cool right?
The butterscotch micarta is from an old drop. The color will eventually turn brown over time.
The micarta on the bottom came from a drop of Westinghouse flat stock. The resin rich surface was intact, but oxygen seeped in through some of the fibers around the sides. Some of the color went pretty deep, creating the unusual mottled appearance. This is a fresh raw cut material that will brown some with age. It is the same Micarta used on this knife:
7.jpg~original
^ the pieces on the dagger were cherry picked from the very center to have a uniform color. That surface was already browning some when that picture was taken.
I'm a denim fanatic. Now I'm jonesin for another Carothers field knife. Good marketing sir. Thanks for sharing the process. The vintage micarta looks great too!
Any chance that the scales would be available separately for those of us that already have one of the field knives?
Sure. The butterscotch and Westinghouse are one of a kind but the other stuff is no problem.
I love almost all old micarta I see. But that butterscotch is some amazzzing stuff.
Nathan, is there a lot of grip difference between the black micarta and the westinghouse micarta?
No. They're both canvas micarta and if you were to close your eyes I don't think you could feel any difference in hand. The Westinghouse material is harder, which is noticeable when sanding it, but the black micarta is Acculam material (made in the USA) and is the closest to the original Westinghouse material that I have been able to find. It's hard enough to take a mirror polish (if that floats your boat) and it's dimensionally stable, like the original.
