- Jun 22, 2002
I have been having problems with my band saw jumping of the bottom wheel for years. I had an old bloke around a couple of days ago to build some forges.
I was cutting some plate and the saw jumped off the wheel twice in a few minutes. He said why don't you adjust it? it is like the belt sander it should have a tracking adjustment. He did not know where but it should.
Well I messed around today and found that the bottom wheel has the blade fed onto it by passing through two ball bearings. I found a bolt behond the bearings which when loose would alow the bearings to pivot and change the blade angle feeding onto the wheel. I adjusted the blade angle and it is like someone elses machine not mine.
I was so happy I had to tell some one. It is like the ones you blokes by from harbour frieght. It can be used as a cutop horisontal style or by adding a small cutting table it can be used in the vertical.
Well I hope that it will help someone. If you need pictures
reg_ellery@optusnet.com.au
