This is definitely a shark tooth. I grew up in Florida and finding/collecting fossilized shark teeth was a very large part of my childhood. I have thousands of shark teeth, some small, some large. I have several that look very similar to what you have there. The shape of the tooth will depend on the species of shark. Some teeth are triangular in shape with very pronounced edges and serrations, others can be conically shaped and very smooth with no edges at all. Yours is missing the top, which would assist in giving it the more recognizable T shape. The flatter side is the front (facing out) while the side with the pronounced curve is actually the back (facing in). The angle that the tooth would sit in the mouth would point the tip up or down and slightly toward the rear so that the prey's act of pulling away would only improve the grip of the sharks teeth. The specific shape of the tooth also changes based on the position of the tooth within the shark's mouth. Shark teeth shed naturally and are replaced on a regular basis. When you find a whole tooth (T shaped), it is likely that it was either shed while the shark was still alive, or was loosened from the jaw after death. Broken teeth (as yours is) were generally either broken by natural processes after the tooth was shed, or was broken off during a feeding.
Your tooth appears to me to be the business end of a mako (Isurus desori, now extinct) shark tooth from a shark about 8' to 10' in length. Great find! Keep looking, where there's one there are usually many more. Search in streams that contain large deposits of pebbles. I used to use an old pasta strainer to scoop a big load of sand and pebbles, then sift it in the water to wash out all the small particles. Then systematically search through the pebbles just looking for something out of the ordinary. I have found teeth about half the size of a grain of rice all the way up to about 5 inches in length.
Here is a link to a pretty good page with sample pics. The third pic down has some nice mako examples, in particular: top row, second from right.
Just to show how different shark teeth can be from each other, compare
these sand shark teeth (long, slender, conical, subtle ridges, no serrations) to
this great white tooth (triangular, flat, serrated). They can be very different, but no matter their shape, I wouldn't want to have anything to do with their use!!
Happy hunting!
