it's the metal plate which size is 650*76*8mmAre you in China? Are these heat treated bars or are they already profiled?
Hoss
thanks for your advice sir.You might need to use waterjet to cut the profile and then may be water cool grinding.
would you like to give me a list of books and the name of special equipments?i have the common equipment to make flintlock gun.You will need to read a lot, do learn to make knives, and build/buy a bunch of equipment to do what you ask. Working with hardened bars of Z-wear is not a beginner's project.
You need belt grinder with some ceramic belts , small angle grinder and tungsten carbide drill bits to drill holes in handle .And some sandpaper for hand sanding ....rest is on you how you use them !would you like to give me a list of books and the name of special equipments?i have the common equipment to make flintlock gun.
You don t need any book , you are on right place here to learn .You will find thousand of topic about belt grinders and other equipment .You will find thousands of topic about anything you need to know .would you like to give me a list of books and the name of special equipments?i have the common equipment to make flintlock gun.
ok sir ,thank you.你不需要任何书,你来对地方学习了。你会发现数以千计的关于砂带磨床和其他设备的话题。你会发现数以千计的关于任何你需要知道的话题。
And a lot of time ….You need belt grinder with some ceramic belts , small angle grinder and tungsten carbide drill bits to drill holes in handle .And some sandpaper for hand sanding ....rest is on you how you use them !
www.bladeforums.com
Hhow useful information! thank you sir.God bless you.如果您查看 Shoptalk 页面顶部的便签,您会发现很多关于制作刀的信息。大部分是针对未硬化的刀片,但原理是一样的。便利贴中还列出了有关制刀的书籍。
粘性也有自定义搜索引擎。使用它并搜索诸如“制刀书籍”之类的内容,您会发现列出了许多书籍的旧线程。搜索引擎可用于查找您想在过去线程中查找的任何主题。
这是我就您对使用预硬化钢的询问提出的问题:
Stock Removal from Pre-Hardened Damascus Billet???
Hello All - I am looking at various sources of damascus billets for several projects I have planned, and am seeing some of them indicating the billett comes pre-hardened (a number of domestic sources indicate an annealed state - but my question is on those indicating a hardened state). WHY...www.bladeforums.com
您最大的问题是在磨削硬化钢时保持刀片冷却。您不希望它在研磨时变得超过 260°C/500°F。每次通过研磨机时都浸入水中。Z-wear 的手工打磨会很慢,但会慢慢进步。
我最后的评论是,如果没有磨刀机和相当多的经验,用硬化的 Z 型磨损制作一把刀不太可能很好。
thank you sir ,thanks for your encouragement.Hey it's a lot at one time! Don't get frustrated!! The only thing I can recommend that has not been mentioned is a book by Dr. Larrin Thomas "Knife Engineering". It might be a bit advanced, but it's definitely worth getting if you are starting out making knives! Good luck brother!
The problem is it's only in English. I'm Estonian so I understand the language barrier!.
It's an excellent cost for the information contained in it also! The book that is.
Welcome to the forum, my son was a US. Marine during the first joint training mission in Estonia, he had nothing but good things to say about the country and the people. Glad you are here.Hey it's a lot at one time! Don't get frustrated!! The only thing I can recommend that has not been mentioned is a book by Dr. Larrin Thomas "Knife Engineering". It might be a bit advanced, but it's definitely worth getting if you are starting out making knives! Good luck brother!
Glad for the USMC!Welcome to the forum, my son was a US. Marine during the first joint training mission in Estonia, he had nothing but good things to say about the country and the people. Glad you are here.
Uncle Sam's Misguided Children!Glad for the USMC!![]()
