I had to try some stropping
I've bought a lot of knives that had crazy grind angles. I bought a Spyderco Sharpmaker a long time ago, the older model that does only 20 degrees, and found that I had a lot of knives with steeper angles. This year I bought a DMT Aligner so I could put new bevels on them. I sharpened several of my knives through the 1200 grit diamond stone and they were pretty sharp, probably sharp enough for me. I had some thin paper and I could barely slice it along the grain but not across the grain.
After reading about strops I thought I would give it a try. I cut a piece of scrap 1/8" balsa wood to match the size of the DMT stones, glued a thin piece of leather to it, and put some polishing compound on it that I had leftover from a past project. The new thing fit on the DMT holder just like a stone and the DMT clamp would hold the angles the same way. I put a dozen passes on each side of the blade and lo and behold that knife was significantly sharper. It would easily slice the paper both directions.
I want to add that the guided sharpened with diamond stones was a great addition to me because so many knives have angles that are not compatible with the Sharpmaker, but the strop is the absolute best thing I have added to my sharpening sytem and very easy to do.
Now that you've discovered the joys of stropping, play around with different compounds, and different strop materials even.
I'd recommend a starting point of Hand American's Chromium Oxide.
Good luck!
