did you remove the etch yourself
I would be interested in how you did it. /Roger
First of all, I am a woodworker not a metalworker so this is new territory and I'm sure there will be comments about, "you should have ..." As I said before, I figured as long as I didn't really screw it up either Heath or Leroy could come to the rescue.
I don't have a buffer, but the thing I do have is plenty of time. In woodworking the main difference between a skilled amateur and someone making a living as a woodworker is time. That means the professional has to use machines, try not to make mistakes and, if mistakes are made, know how to compensate quickly. It also means knowing how to get the same effect using different techniques and tools. Since I retired I have really enjoyed avoiding the noisy machines, and using hand tools as much as possible.
All of this is the roundabout way of saying that I used sandpaper for this job. I started with 600 grit, using a light circular motion, and then followed with 800, 1000, 1500, and 2000. After the 600 grit I kept all motion perpendicular to the length of the blade. The action was rapid, not heavy.
The result is a mirror finish that compares pretty well with the other side of the blade. I still have plenty of time and some 2500 grit, so I may give a finishing touch to the blade. I don't think I'll to send it to Heath or Leroy.
Bert
Are you using wet dry paper with oil? Or just using dry sandpaper?
often I don't mind a blade etch (on a standard grade knife)
