- Mar 4, 2016
The blade is great but the handles are big and boxy. The corners make the grip uncomfortable to handle.
So I would like to replace them with something more ergonomic. I have a great big piece of padauk 2-3/4" thick and first quality.
Here's my concern, and that's I wan't the handle to fit perfectly and flush with the tang but the blade is coated and I don't want to scratch it.
So my naive plan is this- Remove each piece of micarta and use one to trace onto a piece of wood which I make into an exact dimensional copy of the blade from the back of the edge to the rearmost of the tang. I can then use the holes in the one side and mark the center with an awl. I drill that out then reassemble the pieces to the "tang". I then trace the other side and cut the "tang" out and make that as I said exactly like the real tang. Then it's a matter of cutting and rough finishing the paduak scales and attaching them to the wooden tang. Then I can rasp, grind whatever until I have something that's as perfect as I can make it.
This is just off the cuff so I'm interested in opinions of this approach. Also I'm not sure as what a proper handle shape is optimal. It's a heavy duty bushcrafting knife and I'll be using it as such.
So technique, shape, finishing, pretty much the kitchen sink of knowledge would be appreciated.
Edit- I have a complete woodshop except for a lathe including hand tools.
