I made some scales tonight
Bill Siegle
Well I finally got time to do a little scale work for my B11 tonight. Figured since I make knives I would save a few bucks from buying the micarta scales. I dought I saved a penny after it was all done but I did have some fun :) The hard part was creating the little pieces that fill up the handle cut outs. Not easy to work that small of a piece of G10 on the Bader. Then there was drilling the 3/32 holes.......turns out my drill press chuck doesnt hold that small of a diameter drill. Out comes the Dremel and away goes the happiness of a true 90 on my drill press. Glad I didn't have too much Mt Dew today so I still had steady hands. Oh did I forget to mention the screws are just a tad larger in diameter than a 3/32 drill? OK use a little side action with the Dremel to open the holes up! OK holes are drilled and true enough through all the parts. Now how to shape these little scales to contour? Oh I know.........hold on tight with the tips of the fingers on the fast running Bader grinder! That worked :) Now to counterbore the through holes for the scew heads...........proper sized counter bore or 1/4in drill and pray? No counterbore so let's use the 1/4in drill :D Finally getting close. Now to just make those hex head nuts into circular nuts so they will fit a 1/4in conterbore. Hold that 3/4in long screw still while it heats up and keep it spinning so I don't facet the nuts.......WOW! It worked! :D Cleaned it all up and put it together with some Loc Tite so the scales don't loosen. Great feeling little blade now and I probably only spent about $100 of shop time to save what $35? :D OK I am done whining. I am very happy with the results. I won't be doing more but I would highly recomend anyone thinking of scales for this tiny beast consider buying the Kabar scales :)
Does this mean the Bill Siegle $100 line of handle scales is coming out soon? :D
Bill, I let Ethan handle your Jungle Knife at the Spirit of Steel show this past year.
He made me promise that, should I ever sell it, I would sell it to him.
In other words, it got high praise from Mr. Becker.
I have a set of Becker Handles made by Bill Siegle(Bottom one in photo)
and NO--they are not for sale
What are the scales on that rampless BK10 William? ^
I am putting that in my ego vault :D
Bill makes quite a nice Kukri as well Guyon, in fact of all his knives that I have seen, I don't think I have seen one that I don't like.
i have long advocated that if someone didn't want a Becker, they should buy a Siegle, esp for the brute lovers, and khukri lovers. good stuff :)
5160 tool steel, typically, and differential heat treat right? can't ask for better than that ;>
Siegle/Becker Collaboration ?
Bill make more knives !
I love your stuff but can never find any for sale.
Hope you are doing well, and thanks for the reply to my email a while ago.
@ WILLIAM.M
For some reason its not letting me PM you, I have been looking for the long bladed Hoodlum 2, and possibly a Siegle Kuk also.
If you can PM me send me a tell.
Mr. Siegle those are some awesome scales sir.. but with your attention to detail I was kinda expecting a cut out (filler) for the bottle opener and the option(s) for full length scales :D
nice job:thumbup:
Bill, you shaped those itty bits on a BADER?
{hat tip}
(Love those big blades of yours, btw!)
Why the fillers and through-screws instead of ... oh, the sheath?
-Daizee
A lovely job Mr. Siegle, a lovely job indeed........Are you capable of less than lovely work.....If so I have not seen it.......
Being that Guyon is not likely to get up off that jungle knife we should probably talk........
All Best......
ethan
Those look great! I am working on some custom scales for my bk11 and I hope they turn out half that good. Excellent work.
