Naniwa 2k Aotoshi, there is no better.
How fine are you talking? What are you going to be leading into this stone with?
Theres lots of great stones that work well on softer steels both natural and synthetic.
Instead of getting a slow Arkystone, why not get a fine grit waterstone - such as 8K/10K/12K? You get similar finish & consistency much faster with a waterstone.
I am needing a bench stone that is finer for my simpler softer carbon and stainless steels. I am thinking Arkansas. What say you guys?
Chris "Anagarika";14444933 said:Following David (OWE) advice that DMT F-EEF can be used for softer steel, I use DMT Extra Fine (1200) for my wife's Victorinox paring and she likes it better than when I use EEF (8000).
Finished with extra extra light edge leading (no burr). Strop on jeans (no compound) just to clean the remnants if any.
It's important to maintain my wife's happiness regarding the knives
For woodworking, I have no idea.![]()
Well, half the reason I was looking for a finer stone was for gouges and V tools. The other half was for the knives. But I used knives as a catch all for the explanations. I thought that if it would do the soft steel knives, it would do for refining gouges and V tools. If the green brick is too soft to do chisels, I doubt it would work well for gouges. I didn't expect this scenario or I would have advised you of my thoughts.
Jason, I don't sharpen like you or most of the guys on here. All of my reprofiling is done with fine stones. 600 grit diamond or fine side of an SIC or India. I get a sharp, almost completely burr free apex with one stone then strop. This usually gets my edge to almost tree topping. It is just a little short of that sharpness measure. I haven't yet needed more. Except that the India is to coarse for this to work. The Green Brick of Joy + 1000 grit Naniwa sound nice but I am looking for more a more multi purpose stone. I changed my criteria and that was my bad, sorry!
Martin, our kitchen knives get treated like a rented mule. Beaten until they give and then beaten some more. I do the best I can on them. They give me great practice! I have and occasionally use one of the grooved steels you dislike. I don't and wouldn't use it on a good knife. It is ok for beater knives if you strop after you raise a burr with it. Miles better than cutting with a dull knife. And it doesn't destroy the edge like a pull through would.
Chris, I had a gouge that was giving me fits because the apex was chipping out in large chunks on the India. I used a 1200 grit diamond stone with slightly modified technique and got it carving last night. Needs some more work but it is miles better than it came out of the box.
I wonder what you guys would say if you saw me sharpening my woodworking tools right now. I would probably get thrown out of M,T & E!
If you want stone recommendations for razor sharpening its going to be different than chisels and knives. You can get a base set of stones but for speciality tasks like razor sharpening it will need it's own routine. Chisels sharpen a little easier on harder stones but I have used the GB to great effect on chisels and plane blades.
After some thought I still recommend the same stones, below is a plane blade finished on the GB.
No, I am not looking for recommendations for razor stones in this thread. I muddied up the water but you gave me the answers I needed. I am only concerned with knives and woodworking tools right now. So you still recommend the Naniwa 1000 traditional and the Green Brick of Joy? (I have to admit, I like the nickname.) I guess you haven't sharpened a gouge or V tool on it have you?
You could always go back to your original idea and get a soft arkansas and a nice translucent. The soft Arkansas would be a nice transition from your India stone and the translucent would be your finishing stone. These two would fill in your gaps for your pocket knives, kitchen cutlery, and your chisels.
Chris
I could probably get a way with having both the arkasas stones and the Naniwa 1000/Green Brick. I have googled for "Arkansas Stone" but how do I know if the ones I find are good? These aren't manmade stones after all. Should I look for a hard black or a translucent black?
Jason, couldn't I try the Naniwa 1000 first then then get the Green Brick later if I like the 1000? The 1000 you recommended is out of the Traditional series. What is it like? Hard, soft? I guess it is for softer steels IE. 1095, 01 and 154cm. I am learning a lot about water stones, thank you!
I have stones from several different vendors and I have never gotten a bad Norton stone. Halls Pro Edge sells some very good stones as well. I have Arkansas stones from a few different vendors other than these and they are not up to par with the two I have mentioned. All of my Norton stones are 8"x3"x1/2" stones while some of my others are slightly smaller at 8"x2".
I have both the translucent and hard black varieties but I mentioned translucent because it seems to me (and several others I have read from) at least that the translucent's seem to be more consistent across vendors than the black's. It is my experience that the black's vary more from vendor to vendor...other's experience may be different. My favorite hard black is slightly finer than any other stone I have, but my Norton translucent is certainly no slouch either.
As far as the translucent blacks, I think it is just another color variation of the black Arkansas, however I don't have one. Black's range from greyish black to bluish black to jet black. My favorite one is jet black...think of getting in the closet and turning off the lights black.
Best of luck with whatever you choose as we all have our individual preferences.
Chris
Yes, and for most new sharpeners (or new to waterstones) a 1k stone IS your starting point and you build from there. Most any 1k waterstone is going to get the job done but if you have specific needs you can pick a stone or stone sets tailored to the sharpening you do.
The 1k Naniwa traditional stone is like most other red brick 1k stones, it will be about the same cutting speed as your India but yield a finer scratch pattern. It will wear and dish quicker than harder stones like Shapton but the common red 1k stone is the India stone of waterstones. If you go to a hardware in Japan it would be the stone most commonly found.
Basically, no matter what you plan to sharpen this 1k stone could be recommended to do it, just like the India or Cryslolon stones so often recommended in the USA.
To better direct you to a stone purchase answer the following.
What is your budget for a single 1k stone (just to get you started)?
do you sharpen wood working tools more often than knives?
