- Apr 12, 2012
I saw a thread on strop cleaning already, but it was just too much. I need a simple yet efficient way to remove all of the metal that's built up on my strop. Thank you.
If you have a Strop Block, it's incredibly easy to maintain due to the way it is made. Compound is melted into olive oil and hot worked into leather. When it dries, there is a thick layer of compound on the strop which partially penetrates into the leather. When the strop gets loaded and glazed with metal, you dip a finger in olive oil and just rub fresh compound to the surface.
Amazingly, it actually works. A few drops of oil and 1 minute of rubbing with your finger, and you get a nice, clean, swarf-free surface of fresh compound. Then you are ready to strop again. I've had mine for a year, and going strong. The folks at Knives Plus tell me they've been using the same Strop Block for years. I highly recommend it if you want a strop that is easy to maintain.![]()
Moisten a paper towel with WD-40, and just wipe the black stuff from the surface of the strop. That'll do a lot by itself. Re-apply compound as needed. On a day-by-day basis, just wiping the surface of it with a dry paper towel makes a big difference.
This is all I do...works great. Depending on how hard you go at it, you may or may not even need to reload the stop with compound.
