Joseph Bandeko
- Dec 9, 2021
Hello,
I am currently working on this kukri:
And I’m running into a problem I’d like y’all’s help on. The problem is that when I really whale on it, the edge starts to deform over (and by whale on it, I mean chopping really hard into a dry hardwood knot), and it’s coming up further then just the secondary bevel, it’s more like bacon edge from a blade that‘s edge was to thin after you quenched it, and In actuality the very apex is holding up just fine.
So on to the details...
The steel is 8670 from Pops and I’ve actually heat treated it twice, the first time I normalized it at 1550f, thermal cycled once at 1450f, DET annealed at 1380f and austenitized at 1525f, quenched in parks 50 and tempered at 350f. The second time I went ahead and just started over (though a skipped the thermal cycle), this time normalizing at 1575f, annealed at 1380f, austenitized at 1550f and tempered at 320f.
The second time it held up better to testing, but is still taking deformation.
As for measurements, the edge has a slight convex to 0.028” behind the edge (that’s after the second heat treat, the first time it was a little bit thicker), and it’s 20.75“ overall with a 15” blade.
I already feel like the edge is thicker than it should be, but that’s just me.
So what is it that I need to change? Is the heat treat the problem? Is the geometry just to thin? Any Input/advice I can get is greatly appreciated!
Edit: Upon further inspection of the edge under a microscope, the edge has taken some minor chipping, also the edge was sharpened to about 25 DPS (maybe even a little less) so I should probably increase that angle a little bit.
Joseph
Joseph
