I received my 1st Kukhri yesterday...
It was the 16.5" WWII from last weeks UBBB.
Wow. I have never owned a knife that was hand made. All my other knives are from Gerber, Kershaw and Spyderco. I am very impressed with the workmanship of both the blade and the sheath. I think sheathed, it could be used as a bludgeoning weapon.
I'm going on a camping trip in a couple of weeks, so I can't wait to use it!!
:cool: :cool:
Welcome to the Cantina kwkshift!:D First of all read the safety thread if you haven't already. Then sharpen the WW II up to a decent edge for further safety practice and have a great time!:D
Awesome to hear that you received it, Kwk... I was able to get one for my friend either the day after or the next day for my friend, so that one should be here in a little while. It takes a bit longer for me, 'cause it has to go through Canadian customs... Just remember to be safe with it... As Yvsa said, read the safety thread. Remember that it can cut through a heck of a lot more than you might assume that it could. It will surprise you, and just be ready for those surprises. Big knives equal big wounds if you're not careful. Nonetheless, have fun! :D
I've read the safety page and the sharpening page, but I'm looking for some clarification as far as sharpening techniques.
I prefer the style of sharpener that has the crossed ceramic rods just because I feel that it keeps the sharpening more uniform, rather than relying on my free hand sharpening against a strop or a SMT hone.
I may just be over analyzing this whole thing. What do you guys think? What method works for you?
Thanks.
-->Greg
Sharpening freehand takes some practice. Get a couple old kitchen knives at a garage sale or flea market and practice on them. You can experiment and ruin them all you want and won't feel bad about it. When you get your technique down move to your other knives. Once you get the hang of it is not too hard.
First of all = Welcome! and Congratulations!
:cool:
Re: sharpening "Sharpmaker" style
This can be done with all but the biggest khukuris....however there are easier ways to accomplish the sharpening. Allow me to explain:
Your khukuri's edge is not 100% straight - compared to what you would expect from a factory-set edge on a folding knife (such as SpyderCo). So, sharpening in a Sharpmaker is going to be very time consuming - especially the first time - since your blade will also not have a uniform bevel (in either width or angle).
The second problem is the weight and size of the blade. It will be difficult to maintain uniform pressure against the rods (something that's quite easy with a small folding knife).
Even with these 2 things against you, I bet you could still sharpen it ok - others have done it.
That said, there are many other sharpening methods that are much easier to effecuate and maintain.
The first, and probably most widely used here, is to create a small convex bevel. I won't go into that here, but I consider it the #1 choice for any khukuri.
The second, is to "let the tail wag the dog". Instead of a stationary sharpening system with your knife moving.....switch the parts and make the khukuri stationary and your sharpening system moving. The simplest way to explain it is this: hold the khukuri in your left hand, gripping the spine, with the tip pointed away from you....then with the ceramic rod in your right hand, run it along the blade from bolster to tip. If you want to mimic the Sharpmaker system, then angle the khukuri at 25 degrees and keep your rod straight up and down. I prefer to keep the khukuri straight up and down, and angle the sharpening rod to 25 degrees.
Start with an aggressive grit the first time you set the edge - or else you'll be sharpening till the cows come home....lots of steel to remove. Then move to a finer grit.
The benefits of sharpening this way:
1 - you are more prone to "follow the edge" than to try to set a "factory-straight" edge - which can be very frustrating.
2 - you will get more pleasure from working the edge by hand and will soon be able to sharpen it with anything, anywhere. (stick around a while to hear the stories 'round here)
3 - you will be honoring your khukuri's handmade nature by sharpening it the same way it was made.
4 - you will start asking about how to set a convex edge....:D
(but you will have already done it slightly by sharpening freehand)
Whichever way you choose - we won't hold it against you. :p
You asked - I gave you my 0.02
Congrats on your new khuk:)
The 1st and most important rule of using a khuk is to keep all of your fleshy bits away from the sharp side of the knife. If you can manage this, the chances of cutting yourself are greatly reduced:) Sometimes this is easier said than done (as i type this i left hand bandaged from cutting myself baddly not once, but TWICE in two days with two different knives). Just respect the khuk. If you respect it, then it probably won't bite you too bad too often. When it does, just think of those as love bites:) You'll find that this place is full of really helpful guys that would love nothing more than to help you understand, sharpen, and care for your khuks. There are also a few idiots (myself included) that should probably just be ignored and laughed at when we tell our tales of the idiotic things we've done. Welcome to the cantina:) enjoy your stay!
Jake
Hmmm, 25 degrees, huh? I could make a sharpening jig to keep it consistent until I get used to the angle.
Hopefully I'll be fine handling it. I understand that there is no "safety" on larger blades like these. I've been similarly conditioned by carrying a Sig P229 for over 5 years now. They have no safety other than not pulling the trigger. Mmmmm.........Sig. /Homer Simpson
Anyway, I'll see what I can come up with. Thanks for the advise.
-->Greg
I think it's worth the time to learn freehand sharpening. Nothing is worse than sitting in the woods with a dull knife wishing you had your sharpening equipment.
Make sure you test your blade by chopping some stuff before you go on your trip.
Good point Bruise. Maybe we could get Ez-Lap to make a diamond encusted Chakma? Better than just steel...
DMT already does in their DuoFold.:D ;)
I really think that if a person is gonna be doing extensive work in the field that they should have a Blue/Red DMT DuoFold along with them.
The Blue/Red is Coarse/Fine and is about perfect for restoring and maintaining an edge on just about any kind of single or double edged instrument IMO.
And they're not all that spendy either. I'm pretty sure I gave less, maybe quite a bit less, than $15.00 for any of mine that I've gotten at gun and knife shows.
And WallyWorld has a small EZ-Lap in their sporting goods section fer a bit less than $5.00 usually, can't beat them with a stick,:D although they're a little fine for sharpening khuks:(, again IMO.
Khuks are great on camping trips. I got a 12" Villager AK from a daily special and took it with me on a camping trip up the California coast. Unfortunately most of the CA state parks I went to would not allow firewood collecting but somehow I ended up "accidentally" chopping a few branches. :D
I saw a mountain lion while hiking and immediately took my khuk out of my bag and kept moving. A couple of minutes later a rattle snake rattled at me from along the trail. A few days later a pack of coyotes were howling and going through camp trash, I kept my khuk right next to my sleeping bag that night.
As for sharpening I used to use a V shaped carbide sharpener I got a Home Depot for 5 bucks. I have a Lansky system but I could never attach it to the thick spine of the AK. Just recently I figured out that the extra bolts in the Lansky kit are for thicker blades, (I thought they were simply spares in case of loss). :rolleyes: The Lansky does a decent job but I do have problems with the re-curve part of the blade. It does a much better job than I could do by hand with my diamond rod.
Sharpening by hand took (or is taking) a long time for me. Possibly because I'm just slow. Lessee... I first started trying in 2001... now it's ... :eek:
:D
