- Oct 17, 2007
So, I've been wanting to round the edges of my pyroceram platen liner for some time now, but never really had a way to do it evenly or cleanly enough to my liking. I bought a couple of cove/round over bits for ceramic and stone work, but they don't really make them smaller than 1/4", and the grit is pretty coarse anyway, so I more/less scrapped that idea and put it on the shelf, until recently, while looking on AliExpress for some diamond wheels for my bench grinder. I saw where one seller offered to custom make wheels per customer specs, so I drew something up and fired off an RFQ. The first manufacturer said they could NOT make my wheel, but a second shop saw my RFQ and sent me an email.
They WERE able to accommodate my design, so I figured let's give it a shot! It took about a month for them to get it scheduled, and 2 days later (tonight) it was at my door.
Here's some pics of the wheel:
[url=https://flic.kr/p/2hKSerN]
You can see that I had it made to fit my slitting saw arbor.
Here's a view down the edge of the platen after grinding the radius:
[url=https://flic.kr/p/2hKSesV]
Here's an example of a "pre-radius" platen plunge line on a scrap of wood:
[url=https://flic.kr/p/2hKSeqq]
[url=https://flic.kr/p/2hKSen9]
If you look closely, a J-flex belt almost back cuts into the shoulder of the plunge if I hang it over the 90 degree corner and push into the belt.
Here is an example AFTER the edges are rounded:
[url=https://flic.kr/p/2hKSeqf]
[url=https://flic.kr/p/2hKVXqA]
You can see a much more gentle sweep to the plunge, and no potential stress risers to worry about for heat treat.
I'm still playing with the setup a bit, but overall, this worked much better than I expected.
BTW, I'm only using the smaller radius for now about 1/8", but I also have the option of a wider 3/16" radius. I also had them plate the outer edge and the upper and lower flats of the wheel. I figured if I'm paying for a custom grinding wheel, I might as wheel be able to use it for other tasks, like sharpening tooling and whatnot. Also, a wheel has two sides, so why not use both?!
[/url][/url][/url][/url][/url][/url]
