Alan Molstad
Banned
- Aug 13, 2006
I am currently soaking 52100 for 10 mins at 1550F in a digital oven ..should I extend this?
Now that you guys have introduced 52100...
Up to this point I have always just stuck to forging car and truck springs. The advice I got from this forum was to stick to a easy steel with the tools that I have.
However I got some 1&1/4 inch ball bearings and I have my first knife cooling in the forge as I write this to you.
Now after I finish the work with the belt grinder before the heat-treatment, I need to have a plan for how to do the HT.
My tools-
gas forge
O/A torch
Quench tank with 2 gal of Texaco type "A" quenching oil.
Some of the clay used to make a hamon on my katana blades
and a Kitchen oven
What should I do?
How should I heat and quench the 52100 blade?
What type of tool that I own should I use?
How should I temper it?
THE BACKGROUND:
mY 5160 steel blades were aimed at being a knife for outdoor heavy use.
They are hunting blades but also used on jobsites and an Everday carry knife
This new 52100 blade is also aimed at being a blade for field use.
I want it to have an edge that stays sharp a long time.
Im not all that interested anymore in a blade that can bend...(after 3 years of seeking to make blades out of 5160 that can pass the 90deg flex test I have never yet ran into a situation where I needed a knife that can take such a bend. I use my 5160 blade at my work all the time in hard situations, and have never thought that I was 'lucky" I had a knife that can bend)
I would like a nice hamon line, therefore I was thinking of a clay-coated spine.
MY IDEA SO FAR;
#1 - Is to clay coat the spine/tang of the blade to slow cooling in that area in an attempt to get a nice hamon line.
#2 - Heat whole blade in gas forge until non-magnetic
#3 - quench whole blade all at once ,in oil. (oil pre-heated to 160)
#4 - before blade is fully cool to touch, place in kitchen oven at 300 for one hour.
#5 - cool fully to room temp in oven, then heat once again to 300 for full hour.
Will this work?...what should I do different?
