I have wondered about this knife myself.... It looks like a good all rounder to me, in addition to the potential benefits if you need to whip it out in the face of an attack....
Would you say this knife has a thinner, more delicate tip than a Para-Military or Military even? Both those knives have very thin tips.
I have my doubts that S30V would wear that quickly if you are just touching up on fine ceramic.
If you snap the tip off this knife will Spyderco replace it? Does the warranty cover that, if you weren't abusing the knife, like prying with it, for example?
You are aware that this is a folding version of the Shivworks Disciple? If you like it that much you should track a Disciple down. Its a very cool little fixed blade designed by custom maker Trace Rinaldi.
You have me there. One factor is that the P'kal is a relatively expensive knife, for me.
I have 4 plus the trainer, but do not have any folding knife that is more expensive than this one, except for the Lil' Temperance which will get a little more money than a P'kal.
I also have a lot of knives that work nicely for EDC that are less than $50.00, including my Persistence and Tenacious at under $30.00 each, but also lots of models from other companies. I tend to use these for the tasks that are more likely to beat them up.
Gotta agree with the blade steel not wearing too fast. S30V is nice. I managed to ding one tip, my fault, and was dismayed by how much blade length was lost restoring it.
As it was already pointed out, this is a short blade, but i don't want it a lot shorter.
They would replace a knife with a broken tip if it could be determined to be a factory fault, but I don't know how that would happen.
I guess my main point is that if I do pry something, which happens, I would rather use the tanto point on a CS Voyager. It is less likely to break, and if it does, I am out one CS Voyager instead of a Spyderco P'Kal.
The same with my Native. I paid $37.00 for it and the S30V blade will hold an edge similar to the P'kal and much better than the Voyager.
Not too painful financially if I lose, break, or wear it out. It is the main knife that I use lately.
I try not to drink the Shivworks Koolaid completely, but I do have a Clinch Pick that I found used. I have thought about having it "Krein'd".
If I can find a used Disciple at a great price I will probably buy it, but at $240.00, it is a little pricey for me, for a single small blade.
It is also out of stock, and has been since i discovered it, which is probably the true and honest reason that I do not own one.
