- Aug 15, 2005
Greetings everyone,
A few weeks ago I started a thread asking for advice on how to cut G10. I had several hunks of mint green G10 that I got from Canmanstan :thumbup: on eBay (who happens to be on the forum too). The largest pieces were about 12” x 3” x 2”. I had tried to cut them with a metal cutting band saw, but it wouldn’t cut straight. I tried a wood cutting band saw blade, and the G10 immediately removed the saw teeth. I also tried a carbon steel blade on my table saw, but that quickly lost its teeth too.
I received various suggestions on how to cut my G10, which led me to conclude that my best bet would be to obtain a diamond circular saw blade, so that I could cut the stuff on my table saw. I purchased a MK-99 wet/dry turbo diamond blade a couple of weeks ago, but just got a chance to try it tonight.
I bought the blade through Amazon, from a business called Uncle Joe’s. I paid $27.91, shipping included, but it looks like he’s charging a little more right now. He shipped the blade out promptly, so I have no complaints.
I am happy to report that the turbo diamond blade worked great! It zipped right through my blocks of G10, without the sparks and smoke I encountered when I tried a carbon steel blade. The cuts were pretty smooth, although I did find the blade flexed a bit. I would speculate that this is likely due to the mounting system of the blade. It had a diamond shaped hole in it, with an adapter ring in the middle to fit a 5/8” arbor.
I would like to point out that, even with my shop vac hooked up to the saw’s dust port, there still ended up being quite a bit of G10 dust being spewed about. If you try my method, please be sure to wear a mask or respirator (plus eye protection of course). I had a mask, but I forgot to put it on when I started. I made two passes through the G10 before getting it on, and even that was enough to give me a touch of a sore throat and a cough later.
The bottom line is that you can cut blocks of G10 on a tablesaw with a rather inexpensive turbo diamond saw. It makes a bit of a mess (probably no worse than anything else we cut), but cuts quite easily.
Here is what I started with. You can see the places where I made failed attempts to cut the material.
This is the saw blade.
Here are the tools I used, and the G10 I cut. Not shown is my shop vac hooked up to the saw’s exhaust port.
Powermatic PM2000 Tablesaw
Here’s an image of one of my first cuts.
You can see were I paused the piece as it passed by the blade.
After I a little practice with the blade, my cuts did get smoother.
You can see how much dust I got on just my arm. Imagine if you breathed in all that crap?
Here’s the results of about 45 minutes of cutting (including all the measuring, etc.) I reduced my chunks of G10 to more manageable sizes, but created a boatload of dust.
