I think I figured out the pictures?
Here is a small hunter I simply call pearl.
She is 7" overall and has nickel silver furniture and pearl scales.
Her finish is a clean 2000 grit hand rub and the file work is from tip to heal. I have also done this style of blade in Damascus and it looks good too.
I wanted to post a large Bowie but felt that it's best to start small...baby steps and all.
Thanks for looking.
Dale Baxter
pearl%20,jpg
The reason that your picture did not show up was because you typed the wrong URL between the img and the /img. You put ,jpg instead of .jpg.
OK,
it should read imghttp://www.baxterknives.com/Dagger1.jpg/img ?
Or do I not need to put the "IMG" before and the "/IMG" after the link if I am downloading from my website?
this is a link to a different knife on the same website and not the pearl knife.
Thanks for the good comments on the knife.
Dale Baxter
You do need the img between [ and ] before and the /img between [ and ] after the URL or you will only get a link to the picture, not the actual picture.
The best way to post a picture is to right click on the picture on your web site. Click on properties in the little window that opens up. Another window will open up that has the URL in it. Highlight the URL, right click on it and then click on copy. After you have done this open up the Post Reply window here. Just above the box where you type your reply you will see a button marked IMG, click on that. A small window will open. Paste the URL in the box at the bottom and click on OK[/]. That's it. Clear as mud, right?
