I find the Sharpmaker to be best when using micro-bevels. You'll need a coarse stone to go with it, possibly a medium if you get a very coarse stone. I used a Norton Coarse India stone for years. Basically you need a quick cutting abrasive to lower the edge angle below the desired edge angle on the Sharpmaker. I use a 12 degree angle block before going to the 15 degree slots, and a 17 degree block before going to the 20 degree ones. This only takes about 10 strokes per side on the Sharpmaker after raising a burr on the coarse stone. If your stone is very coarse, an intermediate grit will help. I currently use a 220 grit King waterstone followed by a 1000 grit King, then go to the Sharpmaker. It's not absolutely necessary to raise a burr, but it's a sure way to know you've gone far enough. After a few sharpenings, the micro-bevel will get pretty wide, so that the Sharpmaker isn't really effective any more. When this happens, just use the coarse and/or medium stone to reduce the width of the micro-bevel. I like to keep my EDC microbevel at about 1/64" wide. My Cold Steel Scalper is set to 12 degrees per side on my coarse then medium stone (I have a 220/1k combo stone). After it got dull last time, I just went back to the 1k (1000 grit) stone and reduced the microbevel down to just barely visible, then went through the Sharpmaker at 15 degrees. Voila, an edge that will clip hairs above my skin.
Another thing I've been playing with lately is using multiple microbevels. They are so tiny, they really dont' affect cutting much. I have a trapper 2 blade slipjoint that this approach works well on. I set the edge at 12 degrees per side (dps) on the 220 grit, then go straight to the Sharpmaker at 15 dps for the medium stones, and finish off with the 20 dps slots on the fine stones. The last microbevel isn't visible even at 40x magnification. When it's time to resharpen, I start with the 20 degree slots and give it say 20 strokes per side on the fine stones. If that doesn't work, I back up to the medium at 15 dps, and by then I can see what's going on. If that doesn't work within say 100 strokes, or if the 15 degree bevel is getting too wide, I go back to the 220 grit and narrow it down. Once you get a rythem going, 100 strokes takes less than 3 minutes to do. The whole idea is to keep the coarse grit away from the very cutting edge unless you need to remove damage. At the same time, you want to keep the medium and fine grit bevels as narrow as possible, while still getting to the edge, so that these finer grits only need to cut a minimum amount of steel. This makes sharpening very fast. It also lets you be a little sloppy with your angle control, while still assuring the finer grits reach the very edge.
I've had a Sharpmaker a long time and experimented with it a lot. You can free hand the relief bevels before going to the Sharpmaker. I just choose to use the blocks because I'm a control freak.
