I was going to get a 710HS but...
jefroman
....I'm not the greatest shrpener in the world and I've been hearing that re-curves are a pain to sharpen. If that is true, then should I still get one??
Thanks!
P.S. Is it possible/easy to sharpen re-curves on a Sharpmaker?
The 710HS is an awesome knife. You've heard that before. A recurve is not difficult to sharpen. You can't sharpen one on the flat of a benchstone. But you can sharpen one on the edge of a benchstone or on any stone that narrower than the radius of the recurve. A sharpmaker will work very well. Buy it!
Most of my REKAT folders have a "recurved" blade, and I don't have any problems keepin' them SHARP with my Spyderco Sharpmaker....It just takes a little bit more care (attention) than sharpening a "straight" blade does.:).
Originally posted by jefroman
....I'm not the greatest shrpener in the world and I've been hearing that re-curves are a pain to sharpen. If that is true, then should I still get one?? Thanks!
Come on Jefroman... I know you can do it.
You can pick a knife, I just know it.
And you can choose a sharpener, I just KNOW it.
The Sharpmaker will make the recurve easy to sharpen.
The recurve on the 710 is easy to sharpen with a jig type (Lansky) system also.
This group has spoon fed you with valuable and hard-won information, fresh, typed up, even though it was all available via search engine.
But, you must take the next step on your own... I know you can do it.
I'm rooting for you....go Jefro! GO!
http://www.bladeforums.com/forums/showthread.php?s=&threadid=162063
http://www.bladeforums.com/forums/showthread.php?s=&threadid=161684
http://www.bladeforums.com/forums/showthread.php?s=&threadid=163244
http://www.bladeforums.com/forums/showthread.php?s=&threadid=162954
http://www.bladeforums.com/forums/showthread.php?s=&threadid=163013
http://www.bladeforums.com/forums/showthread.php?s=&threadid=162280
http://www.bladeforums.com/forums/showthread.php?s=&threadid=162470
http://www.bladeforums.com/forums/showthread.php?s=&threadid=161292
http://www.bladeforums.com/forums/showthread.php?s=&threadid=161228
http://www.bladeforums.com/forums/showthread.php?s=&threadid=164319
Jeff
The 710HS is an awesome knife. You can easily maintain the recurved blade on the Sharpmaker 204, using the corners of the stones, not the flats. It works like a charm.
Come on Jefroman...pull the trigger and worry about the details later. You will not be disappointed. I used to think the 710 was a little big for my tastes, but I am beginning to reconsider. It may be the perfect tough as nails user.
If you like something smaller, I just picked up a 812HS and it is holding up great.
BTW...did you get the e-mail I sent you on where to get the 710 at a pretty good price. Also...if you decide to get the 812HS, I got a place you can get those pretty cheap too.
Good Luck...JT
Jefroman,
Invest in a Sharpmaker 204. I say "Invest" because acquiring a 204 is well worth the $$ you put in it. You will have the ability to sharpen anything in your house that has a sharp edge. Re-curve edges will be nothing for you to sharpen. Nor will virtually anything else with an edge.
That reasoning aside, you are going to miss out on what may very well be one of the finest folders to ever come out of a factory in our lifetime. Well, one of the finest anyway.;)
Not that I want to be the only dissenting voice here, but I wouldn't buy a 204 Sharpmaker until they start putting out coarse grit sharpening sleeves or rods. The sharpening media that they have on there just doesn't take off enough metal fast enough. Since most Benchmades seem to be sharpened fairly high angled, you'd better have a lot of patience using the 20-degrees or 15-degrees on each side setting.
Not many people have thought about this before, but the Lansky system will do a pretty nice job on lightly recurved blades with just the standard hones (you don't need the V-shaped hone). In fact, I even managed to turn a BM 730 into a recurve on the Lansky (using an extra coarse stone and a bit of patience), which one of my friends thought was pretty cool. It might round the corners on your sharpening stones a little bit, but it's really no big deal.
