- Apr 18, 2014
So i have a question to anyone who has any experience using and finishing buckeye wood and especially buckeye burl. While i believe buckeye is still classified as a hardwood, it is of extremely low density. Because it is so soft, it is actually extremely easy to carve, shape, and sand imo. However, is is very difficult to get a smooth finish on when going up to finer grit sandpaper, as it remains soft and somehow.. fuzzy. A solution to this, i have found, it simply to use sanding sealer like you would any especially soft un-stabilized wood. This way is get a more hard glossy look. However, i still have a strange problem ive only seen with buckeye burl. Because of the marbled look of various dark and light colors like blackish green and light yellow, and because of the soft consistency, i seem to blur out the beautiful definition when sanding. Basically, instead of with some hardwoods where i sand it until smooth, taking of the very top layer and blowing it off, the sawdust and grit is being forces into the pores of the wood it seems. Its almost like smearing the dark blackish sawdust around and messing up the yellow until much of it is grey. Ive never really seen this to the extent i am with buckeye and not sure how to fix this. Thank you for an advice
