- Feb 1, 2000
I have a two wheel Pro-cut 2x72 grinder. I like tapered tangs on my knives and the grinder isn't a problem on knives that I forge because I start the taper while forging. I can then lay the taper flat on my platten to clean it up without the blade touching the belt.
My problem comes into being when I want to do a tapered tang on a stock removal knife. The only other time I've done this was on a Wilton square wheel grinder at a friends shop where I could just grind the tang while the blade hangs completely off of the platten. Since the platten on my grinder lies between the wheels and is in line with the belt I can't do that.
My first thought was to build a new platten for my machine with a shallow triangular shape, instead of being flat, so that I would have a portion of the platten to grind the tang taper on without the blade touching the belt. Seem like a good idea? Or will the new platten put too much tension and friction on the belt?
